[gdal-dev] Join problem
William Kyngesburye woklist at kyngchaos.com
Mon Oct 28 19:35:18 PDT 2013
After renaming the field with alter table the join now works.
On Oct 28, 2013, at 8:26 PM, William Kyngesburye wrote:
> I'm having a problem with with a join.  I suspect it has something to do with the field names.
> The shapefile DBF and the lookup DBF have a field name in SJIS: "土地利用種".  The lookup table also has a field "class".  ogrinfo gives me the correct SJIS->UTF8 conversion of the field name in the terminal.
> ogr2ogr -sql 'SELECT b.class FROM "L03-b-09_5133" a LEFT JOIN "/path/to/class.dbf".class b ON a."土地利用種" = b."土地利用種"' . L03-b-09_5133.shp
> This just gives me a SQL syntax error.
> I've successfully run other OGR SQL with the SJIS field, like casting it.  Maybe that's what I should do - cast it to rename it, then do the join (and rename the lookup dbf field also)?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
