[gdal-dev] gdal_translate failing with Corner Coordinates for geotiff
Jan Martin janmartin at diy-streetview.org
Tue Oct 29 04:37:08 PDT 2013
Hello all,
I am trying to create a geotiff from a .png (screenshot for testing), but
gdal_translate gets the corner coordinates wrong.
My steps:
Works with Chrome Browser only:
http://overlay-tiler.googlecode.com/svn/trunk/upload.html
with screenshot:
http://www.diy-streetview.com/data/geotiff/Neurott.png
and
Ampèrestraße 63225, Langen, Hessen, Germany
gives:
gdal_translate \
 -gcp 0 0 8.648622773788475 50.00162255942198 \
 -gcp 644 0 8.655532144210838 50.00162255942198 \
 -gcp 644 899 8.655532144210838 49.99542253867455 \
gdal2tiles.py -s EPSG:4326 -z 16-19 out.png out
Entering the local file names:
gdal_translate \
 -gcp 0 0 8.648585222862266 50.001663936185025 \
 -gcp 644 0 8.65549459328463 50.001663936185025 \
 -gcp 644 899 8.65549459328463 49.995463920773624 \
 /home/me/geotiff/Neurott.png /home/me/geotiff/Neurott.tiff
seems to work, but
gdalinfo /home/me/geotiff/Neurott.tiff
shows that the Corner Coordinates are the pixel values, and not the lat/lon
coordinates:
Size is 644, 899
Coordinate System is `'
GCP Projection =
GCP[  0]: Id=1, Info=
          (0,0) -> (8.64858522286227,50.001663936185,0)
GCP[  1]: Id=2, Info=
          (644,0) -> (8.65549459328463,50.001663936185,0)
GCP[  2]: Id=3, Info=
          (644,899) -> (8.65549459328463,49.9954639207736,0)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  899.0)
Upper Right (  644.0,    0.0)
Lower Right (  644.0,  899.0)
Center      (  322.0,  449.5)
Band 1 Block=644x4 Type=Byte, ColorInterp=Red
Band 2 Block=644x4 Type=Byte, ColorInterp=Green
Band 3 Block=644x4 Type=Byte, ColorInterp=Blue
How to fix this?
I tried with
GDAL 1.11dev, released 2013/04/13
installed on ubuntu via sudo apt-get install gdal-bin
and
GDAL 1.10.1, released 2013/08/26
compiled locally on Ubuntu 64 bit, 12.04.3 precise.
Both get this wrong.
Any ideas?
Thanks,
Jan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131029/968ae0e5/attachment.html>
