[gdal-dev] Using a MapQuest TMS via GDAL
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Oct 30 02:12:27 PDT 2013
Chris Hanson <xenon <at> alphapixel.com> writes:
> Followup with one additional question.
> MapQuest apparently now requires an API key be specified:
http://developer.mapquest.com/web/products/open/forums/-/message_boards/view_message/459733
> I didn't at a glance see any way to specify this via the GDAL WMS XML. Am
I missing something?
They speak about the static map API but I suppose you do not use that. In
the last message Brian Coacley writes "The tiles do not require a key at
this time. " Is this changed?
-Jukka Rahkonen-
