[gdal-dev] GDAL 1.10 build fails on FreeBSD
Frank Broniewski brfr at metrico.lu
Tue Sep 3 05:55:20 PDT 2013
Hi all,
I tried updating Gdal to the latest version on my FreeBSD system, but
the build fails:
<snip>
c postgisrasterdataset.cpp  -fPIC -DPIC -o ../o/.libs/postgisrasterdataset.o
postgisrasterdataset.cpp: In function 'void GDALRegister_PostGISRaster()':
postgisrasterdataset.cpp:2096: error: 'GDAL_DMD_SUBDATASETS' was not
declared in this scope
gmake[2]: *** [../o/postgisrasterdataset.lo] Error 1
gmake[2]: Leaving directory
`/usr/ports/graphics/gdal/work/gdal-1.10.1/frmts/postgisraster'
gmake[1]: *** [postgisraster-install-obj] Error 2
gmake[1]: Leaving directory
`/usr/ports/graphics/gdal/work/gdal-1.10.1/frmts'
gmake: *** [frmts-target] Error 2
*** [do-build] Error code 1
</snip>
PostGIS is
POSTGIS="1.5.3" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012"
LIBXML="2.7.8" USE_STATS (procs from 1.5 r5385 need upgrade)
so apparently no raster support ...
Is this a GDAL issue or shall I report this to the FreeBSD crew? Or is
my PostGIS too old ???
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
