[gdal-dev] GTiff stack to NetCDF
Etienne Tourigny etourigny.dev at gmail.com
Tue Sep 3 07:15:50 PDT 2013
what you want is probably outside the scope of gdal. It would require some
clever metadata management so that gdal_translate puts them in a single
file...
I would advise you convert them all to netcdf using gdal_translate and then
use python-netcdf4 (not the one from numpy/scipy) to stack them in the
temporal dimension.
On Mon, Sep 2, 2013 at 7:09 PM, David Shean <dshean at gmail.com> wrote:
> Hi list,
> I'm trying to package a timeseries of GTiff rasters with identical
> projection/extent/resolution as a single NetCDF file for distribution.
>  I've spent the past hour consulting the online doc and playing with
> gdal_translate, gdalbuildvrt and gdalwarp without any success.
> Is there an easy way to do this using existing gdal command line
> utilities?  I figured I'd ask before resorting to a custom solution using
> the NetCDF Python API.
> Thanks.
> -David
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130903/a823d6cb/attachment.html>
