[gdal-dev] HFA and RAT
Ivan Lucena lucena_ivan at hotmail.com
Tue Sep 3 19:57:20 PDT 2013
Hi Sam,
Assign the ticket to me and I will apply the patch.
Thanks,
Ivan
Date: Wed, 4 Sep 2013 09:47:48 +1200
Subject: Re: [gdal-dev] HFA and RAT
To: lucena_ivan at hotmail.com
CC: gdal-dev at lists.osgeo.org
Hi Ivan,
Yes I can see this also with the trunk version. The problem is that with the RFC40 changes the HFA driver always returns something from GetDefaultRAT even if it is an empty table - you can now start writing data directly into the table with the returned object.
Below is a patch to prevent the Serialize() method returning anything when the row and column count is zero. I will submit this as a bug report if people think it is a good workaround.
Sam.
--- gcore/gdal_rat.cpp.orig     Wed Sep  4 09:27:51 2013
+++ gcore/gdal_rat.cpp  Wed Sep  4 09:28:33 2013
@@ -502,6 +502,9 @@
     CPLXMLNode *psTree = NULL;
     CPLXMLNode *psRow = NULL;
+    if( ( GetColumnCount() == 0 ) && ( GetRowCount() == 0 ) )
+        return NULL;
     psTree = CPLCreateXMLNode( NULL, CXT_Element, "GDALRasterAttributeTable" );
On 4 September 2013 08:22, Ivan Lucena <lucena_ivan at hotmail.com> wrote:
Take any image, a screenshot of your desktop for example, save it as .bmp "gdal_translate" it to HFA, .img file, and run gdalinfo on it (trunk version). It's only me or at the end of the gdalinfo report do you also see <GDALRasterAttributeTable /> for each band?
Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
  Description = Layer_1
  Metadata:
    LAYER_TYPE=athematic
Band 2 Block=64x64 Type=Byte, ColorInterp=Undefined
  Description = Layer_2
  Metadata:
Band 3 Block=64x64 Type=Byte, ColorInterp=Undefined
  Description = Layer_3
  Metadata:
It seems to me that the HFA driver is reporting incorrectly when the GDAL API function GDALGetDefaultRAT is called by gdalinfo.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130903/69ecacea/attachment.html>
