[gdal-dev] GDAL 1.10 build fails on FreeBSD
Frank Broniewski brfr at metrico.lu
Wed Sep 4 01:32:51 PDT 2013
Am 2013-09-03 14:55, schrieb Frank Broniewski:
> Hi all,
> I tried updating Gdal to the latest version on my FreeBSD system, but
> the build fails:
> <snip>
> c postgisrasterdataset.cpp  -fPIC -DPIC -o
> ../o/.libs/postgisrasterdataset.o
> postgisrasterdataset.cpp: In function 'void GDALRegister_PostGISRaster()':
> postgisrasterdataset.cpp:2096: error: 'GDAL_DMD_SUBDATASETS' was not
> declared in this scope
> gmake[2]: *** [../o/postgisrasterdataset.lo] Error 1
> gmake[2]: Leaving directory
> `/usr/ports/graphics/gdal/work/gdal-1.10.1/frmts/postgisraster'
> gmake[1]: *** [postgisraster-install-obj] Error 2
> gmake[1]: Leaving directory
> `/usr/ports/graphics/gdal/work/gdal-1.10.1/frmts'
> gmake: *** [frmts-target] Error 2
> *** [do-build] Error code 1
> </snip>
> PostGIS is
> POSTGIS="1.5.3" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012"
> LIBXML="2.7.8" USE_STATS (procs from 1.5 r5385 need upgrade)
> so apparently no raster support ...
> Is this a GDAL issue or shall I report this to the FreeBSD crew? Or is
> my PostGIS too old ???
> Frank
Got it working, it was a FreeBSD issue:
http://freebsd.1045724.n5.nabble.com/GDAL-1-10-build-fails-on-FreeBSD-td5841243.html
Thanks to everybody for responding ...
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
