[gdal-dev] GDAL Warp API Java bindings
Florent JITIAUX fjitiaux at gmail.com
Thu Sep 5 10:23:39 PDT 2013
in fact with the Java binding there's no method to get a BufferedImage from
a Dataset.
You can warp your image and get a Dataset
You have to create a (Java)Raster and fill it with the raster or a part of
the raster of the warped Dataset.
But be carefull because when you create a Raster you must create a correct
SampleModel and the right DataBuffer generally Byte or Int, it depends of
the type of the raster in the Dataset.
Florent
2013/9/5 Markus Schneider <schneider at occamlabs.de>
> Hi again,
> I would like to try using the Warp API from Java. It seems that there
> are currently no Java bindings available.
> - Did anbody work on Java bindings for the Warp API?
> - How hard would it be to define them? I may be able to invest some time
> here.
> Best regards,
> Markus
> Markus Schneider
> CEO
> Occam Labs UG (haftungsbeschränkt)
> Godesberger Allee 139
> 53175 Bonn, Germany
> +49 228 93798874
> http://www.occamlabs.de
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130905/88c31f8b/attachment.html>
