[gdal-dev] MOD13C2 assign coord. sist.
Jose Gomez-Dans jgomezdans at gmail.com
Fri Sep 6 02:53:16 PDT 2013
Hi Eloi,
I think that the projection for the global CMG MOD13 products is lat/long,
and is stored in the dataset itself (I deleted the MOD13's last weeek, so
can't check ;-D). You shouldn't need to specify it, GDAL will pick it up.
In case it doesn't pick it up, you want "EPSG:4326", but I'm sure it will
do.
Hope that helps,
Jose
On 6 September 2013 10:36, Eloi <eloi at openmailbox.org> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> I am trying so assign the coordinate system to MODIS product MOD13C2
> but do not know what string use to do this.
> gdal_translate -a_srs 'do not know what to put here' -of GTiff
> 'HDF4_EOS:EOS_GRID:"MOD13C2.A2000032.005.2006272104028.hdf":MOD_Grid_monthly_CMG_VI:CMG
> 0.05 Deg Monthly NDVI' ndvi_sinu.tif
> Thanks in advance,
> Eloi
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJSKaIrAAoJEP9qulIE6g+yAxYIAJUbtd8ZPBBF44aI+v5/vheT
> NV68vtbL39O1tlurN1YQPHsIESr+0pApHDBQO9DPjhbVZG7lK9Pvp4Sef/NzVuFY
> banH9cM29a2aVm/jpLm9FjpRpp+EqV8KX7WQLujxPk7DRd4V0vilTqzFiK20Ebtd
> jCDE2jdzZHyN3jCfc09hsystM1gqFa3wE+Cdsm1a8WdCU9iR8EflEdDgRVD1nvaO
> PeWDbAZvy7nHx/Dlbz4R0vFihZuKiwzniPE/UdB06r6pzG6OtWkQAgEfxT6wh7Tw
> 8pASW1F/YpeX4gyiKxCfUfG0lE9AoYzUaCCvGGG43W1NnInutgcAajmqLVHW8J8=
> =iXGc
> -----END PGP SIGNATURE-----
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130906/3d76398a/attachment.html>
