[gdal-dev] gdal_translate -outsize resampling method?
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Sep 6 03:21:31 PDT 2013
Eloi <eloi <at> openmailbox.org> writes:
> Hi all,
> What is the resampling method used by gdal_translate when using the
> -outsize option?
Nearest neighbor. Use gdalwarp if you want to use some other resampling.
-Jukka Rahkonen-
