[gdal-dev] ogr2ogr load shape in tablespace
Clay, Bruce
bclay at ball.com
Thu Sep 12 05:26:13 PDT 2013
I need to load a set of shapefiles into a tablespace (on a different hard drive) where I have more dataspace. I have been using ogr2ogr to load shapefile up to this point using windows command prompt and batch files. I created a tablespace using pgAdminIII but I can not find a way to assign the data to the tablespace from ogr2ogr. I googled but did not find a way to do so.
Is there a way not listed in the help function or docs?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130912/6cc4dda8/attachment.html>
