[gdal-dev] How to use projection of a shapefile in order to have a better view in OpenGL
sepideh sepideh.abadpour87 at gmail.com
Sat Sep 14 15:32:38 PDT 2013
showShapefile.rar
<http://osgeo-org.1560.x6.nabble.com/file/n5077865/showShapefile.rar>
Dear reader
In the attached file, I have included a program that shows a polygon .shp in
OpenGL. My problem is after finishing the work I found that the layer, is
not shown as it is shown in the ArcGIS or global mapper. I mean it seems
that the layer is stretched.
So two questions rose up for me:
Can using projection of the layer help me? How? I mean how can I apply the
projection of layer to OpenGL?
As you see the OpenGL is using an ortographic projection (glOrtho). Do you
think using (glFustrum) instead will solve my problem and I can ignore
projection of layer?
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-projection-of-a-shapefile-in-order-to-have-a-better-view-in-OpenGL-tp5077865.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
