[gdal-dev] Geo::GDAL for GDAL 1.10.1?
Hernán De Angelis dhdeangelis at gmail.com
Tue Sep 17 08:11:07 PDT 2013
Thanks for the answer Ari. The current behavior is possibly not optimal,
but it is OK anyway. As you say, the paths are system dependent. I just did
not know that it worked that way because I always installed Geo::GDAL from
CPAN.
Thanks again!
Hernán
2013/9/17 Ari Jolma <ari.jolma at gmail.com>
>  On 09/17/2013 05:54 PM, Hernán De Angelis wrote:
>  Nevermind, I found it in
> /usr/local/lib/perl5/...
>  Made it work adding it to my local Perl path (@INC)
> I always compile the Perl bindings separately and leave the --with-perl
> away from configure. That's "cd swig/perl; make; make test; make install".
> I know this may not be what I should do.
> However, there is something strange with the perl Makefile.PL part (done
> automatically by make). The installation target is often architecture
> dependent path - where Perl itself does not find them - and when I delete
> that path and redo perl Makefile.PL and install again they go to the
> correct directory.
> Still one more thing, if 1.10.1 is the very latest with Evan's multiple
> geometries per feature, I suspect that it may have some implications in the
> Perl bindings. There are quite a lot Perl stuff in the bindings (maybe even
> too much) and some of them might assume only one geometry per feature.
> Cheers,
> Ari
>  Thanks anyway
>  H.
> 2013/9/17 Hernán De Angelis <dhdeangelis at gmail.com>
>>   Dear all,
>>  I cannot figure out how to get the Geo::GDAL module installed in my
>> system. I understand that the bindings are built when compiling GDAL with
>> the --with-perl option, but I cannot see where the Geo::GDAL modules are,
>> so I can load them with "use Geo::GDAL". I will appreciate any hint on
>> this, thanks in advance
>>  Hernán
>> Hernán De Angelis
>> http://talesoficeandstone.blogspot.se/
> Hernán De Angelis
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
Hernán De Angelis
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130917/a2e8931f/attachment-0001.html>
