[gdal-dev] HDF5 problem [Caution: Message contains Suspicious URL content]
Lodron, Gerald Gerald.Lodron at joanneum.at
Tue Sep 24 04:15:41 PDT 2013
Thanks for that hint,
Ya the binaries from web seems to work. In my compilation there is no gdal_HDF5Image.dll. Is it compiled with the plugin HDF5 or where I can enable it? I searched the whole source tree in gdal but did not find any text passage with gdal_HDF5Image.dll
PS: Sorry for my double post, my prior mail was written after this mail, I wrote this email in the morning and forgot to click the send button....
Best regards
Gerald
-----Ursprüngliche Nachricht-----
Von: Even Rouault [mailto:even.rouault at mines-paris.org]
Gesendet: Montag, 23. September 2013 21:21
An: gdal-dev at lists.osgeo.org
Cc: Lodron, Gerald
Betreff: Re: [gdal-dev] HDF5 problem [Caution: Message contains Suspicious URL content]
Gerald,
> I have a .hdf file (Conventions=ODIM_H5/V2_1) which i want to open
> with gdalinfo.exe whereby i use gdal 1.10.1 with openjpeg 2.0.0 and
> the HDF plugin of HDF5 1.8.11 (compiled with zlib 1.2.8 and szip 2.1)
> on 64 bit compillation.
> The gdalinfo output prints a lot of subdatasets (1 to 88) but when I
> want to open any subdataset I get many erros:
> If someone has a suggestion how to read in the images it would be nice
> to tell me or give me a hint where to find help.....
Can you also try with the builds available at http://www.gisinternals.com/sdk/ ? If you still reproduce, a link to this dataset (or any reproducing the same
behaviour) could be helpful.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
