[gdal-dev] does ogr_geocode and ogr_reverse_geocode use the GDAL Proxy parameters?
lucvanlinden luc.vanlinden at gmail.com
Tue Sep 24 04:17:07 PDT 2013
Hi
We succesfully used the ogr_geocode & ogr_reverse_geocode before. (Thanks
for your work on this Even).
Now I need to use this but from behind a firewall.
I found the general parameters GDAL_HTTP_PROXY parameters here
http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDALOGRHTTPoptions
My question is: will these be picked up by the ogr_geocode &
ogr_reverse_geocode functions in a -sql select statement for ogrinfo and
ogr2ogr?
(PS: the user is in a domain, what would be the user:password notation
then)?
Thanks
Luc
View this message in context: http://osgeo-org.1560.x6.nabble.com/does-ogr-geocode-and-ogr-reverse-geocode-use-the-GDAL-Proxy-parameters-tp5079555.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
