[gdal-dev] Config option OSM_CONFIG_FILE missing from wiki
Even Rouault even.rouault at mines-paris.org
Sat Sep 28 01:34:26 PDT 2013
Le vendredi 27 septembre 2013 16:20:46, Jukka Rahkonen a écrit :
> Hi,
> Wiki page http://trac.osgeo.org/gdal/wiki/ConfigOptions is listing a whole
> bunch of different config options but not OSM_CONFIG_FILE.
> Meaning of this option as described on the driver manual page
> http://www.gdal.org/ogr/drv_osm.html is:
> "In the data folder of the GDAL distribution, you can find a osmconf.ini
> file that can be customized to fit your needs. You can also define an
> alternate path with the OSM_CONFIG_FILE configuration option."
Jukka,
Feel free to edit the wiki page to document the option. It is a bit difficult to
keep information in sync between that page and the documentation of drivers.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
