[gdal-dev] Weird issue when running gdaltranslate
Moses.Gone at t-systems.com Moses.Gone at t-systems.com
Tue Apr 1 00:31:13 PDT 2014
Hi everyone,
I am getting this weird error when I try to convert a vrt to a tif.
Some context: We are tiling a set of tifs(in a list file). First we generate a vrt from the list. Then we assign a projection on the generated vrt using gdaltranslate. We then clip the output using gdalwarp applying a clipping at the same time to the desired BBOX(This is achieved using the -te option). In the warp operation we also specify the target SRS(using the -t_srs option). Lastly we tile using our customized gdal_retile.py. All is fine with the projection and clipping, but the resultant tiles are empty-no data just white images.
So I tried to backtrack my steps, to check at what point is the data being lost. Generation of the VRT works fine. However, performing gdaltranslate to assign the source SRS on the VRT result into this error:
bash-2.05$ gdal_translate -of GTiff ffm_dtk200_wdd.vrt test.tif
Input file size is 2147483647, 2147483647
0ERROR 1: GTiffCreateCopy():No space for strip arrays
ERROR 1: MissingRequired:TIFF directory is missing required "StripOffsets" field
I tried to also convert to AAIGrid format, thinking that something is wrong converting to Tiff, but also got this error:
bash-2.05$ gdal_translate -of  AAIGrid ffm_dtk200_wdd.vrt test3
0ERROR 1: CPLMalloc(-4): Silly size requested.
ERROR 1: ffm_dtk200_wdd.vrt, band 1: The buffer into which the data should be read is null
Segmentation Fault
Other tiling jobs following a similar method, with different source data works fine though. Could the problem be with the data? If so how comes it worked before?
Regards,
Moses
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140401/65511f32/attachment.html>
