[gdal-dev] Misc. subjects : OSGeo Vienna code sprint, release plans, GDAL 2.0
Etienne Tourigny etourigny.dev at gmail.com
Tue Apr 1 11:36:25 PDT 2014
The 2 objections I have with json are :
- it is so verbose that editing by hand is not as easy as .csv
- the xml tags make file size much larger than .csv files, unless they
would be stored in a compressed file (gzip)
On the other hand, who messes with theses files on a regular basis anyway?
It seems like a nice idea. In what ways would it be better than Even's
suggestion to use sqlite?
On Mon, Mar 31, 2014 at 4:37 PM, Dmitriy Baryshnikov
<bishop.dev at gmail.com>wrote:
>  Hi,
> I think the JSON format is good for metadata storing and representation.
> JSON support to store string, digits, bool, dates, etc. Write such data and
> read such data from files.
> But need good library or set of classes to work with it in memory
> representation.
> For example I like  wxJSON - it support to get value by name or iterate
> values by index.
> int majorVer = root["wxWidgets"]["Version"]["Major"].AsInt <http://wxcode.sourceforge.net/docs/wxjson/classwxJSONValue.html#9223209e7eea4dd4d668869b69560acb>();
> root["wxWidgets"]["Authors"][0] = "J. Smart";
> root["wxWidgets"]["Authors"][1] = "V. Zeitling";
> root["wxWidgets"]["Authors"][2] = "R. Roebling";
> It consist only 3 files (json reader, json writer and json value).
> It seems to me that json-c library is more complicated. Unfortunately
> wxJSON cannot be used in GDAL as it have bindings to wxWidgets library, but
> the approach is interesting. By the way wxWidgets have more democratic
> license instead of qt.
> Best regards,
>     Dmitry
> 31.03.2014 23:03, Even Rouault пишет:
> Hi Etienne,
> Thanks for your ideas.
>  Hi all,
> I have a few suggestions for gdal 2.0, based on my personal experience in
> learning to use, enhance and maintain gdal/ogr code.
> - replace cpl/csl/string/xml code with a mainstream, modern cross-platform
> toolkit such as QT, boost, etc.
>  QT is certainly a dependency we wouldn't want to draw. Too big for some
> embededded usage, and it would make GDAL to be practially bound by the LGPL.
> I guess standard C++ libraries classes, or perhaps boost, should do the job
> for what you mention below.
>  While cpl/csl classes are robust and "do the job", they are not well
> documented and not very intuitive for a new gdal coder. This is from my
> personal experience, some may not agree.
> They are also not used outside gdal, as such do not benefit from
> enhancements as other toolkits.
>  Well, at least, MapServer uses a few CPL functions : CPL minixml,
> CPLMalloc/CPLFree, CPLReadDir, CPLFormFilename, CPLGetFilename,
> CSLInsertString, etc..
>  The drawback is that some data/methods would not be easily available in c
> and other bindings. Also it might not be available for all platforms.
> Existing code would still be able to use cpl/csl code but be deprecated
> until a given release.
> - upgrade/migrate gdal support file (files in .csv format such as gcs.csv)
> reading to use containers (e.g. hash maps) instead of reading the relevant
> .csv files every time
> Current reading of gdal support files is sub-optimal as any query for
> support data requires reading the relevant support file(s). It would be
> more efficient to read these once and cache into a container (such as hash
> map). This could be done using a cross-platform toolkit mentioned earlier.
>  Another option would be to use a .sqlite database with proper indices. SQLite
> would become a runtime requirement, but I don't think that would be a big
> problem.
> - modify metadata treatment to be able to store/retrieve data in formats
> other than strings (e.g. floats, doubles, boolean), and query the actual
> type of a given metadata item.
> Currently there is no way to know if a given metadata item represents an
> integer, float, double (or string).
> In the netcdf driver, I overcame this limitation in 2 ways:
> 1) parsing the value to test if it is an int, float or double (potentially
> error-prone)
> 2) add an extra metadata item to specify the type of the data represented
> (cumbersome and non-standard)
> My suggestion would be to be able to store metadata value along with its
> data type (default string as previously). This would require some kind of
> container for internal representation (e.g. in qt: QMap<QString, QVariant>)
> and a way to represent this on file (as .aux.xml or otherwise in files that
> support metadata) such as gtiff. Values could be stored as strings to avoid
> big/little endian conversion problems. Data type could be stored in a
> (hidden) metadata domain, one item for each "real" metadata key.
>  Interesting idea.
> Well, we need coders now ;-)
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140401/488ac701/attachment.html>
