[gdal-dev] Set max value of "1.#IO" in Geotiff to nodata
Moskovitz, Bob@DOC Bob.Moskovitz at conservation.ca.gov
Tue Apr 1 17:20:54 PDT 2014
Hello gdal,
I have a set of geotiffs that have a strange max (infinity?) values that I would like to set to nodata.  These originally were netcdf files.  With the current of gdal in OSGEO4W, gdalinfo reports:
gdalinfo -mm pola_cascadiad_sift2_maxspeed.tif
Driver: GTiff/GeoTIFF
Files: pola_cascadiad_sift2_maxspeed.tif
Size is 1810, 1100
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-118.302500000118700,33.779999999966194)
Pixel Size = (0.000092592592580,-0.000092592592587)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-118.3025000,  33.7800000) (118d18' 9.00"W, 33d46'48.00"N)
Lower Left  (-118.3025000,  33.6781481) (118d18' 9.00"W, 33d40'41.33"N)
Upper Right (-118.1349074,  33.7800000) (118d 8' 5.67"W, 33d46'48.00"N)
Lower Right (-118.1349074,  33.6781481) (118d 8' 5.67"W, 33d40'41.33"N)
Center      (-118.2187037,  33.7290741) (118d13' 7.33"W, 33d43'44.67"N)
Band 1 Block=1810x1 Type=Float64, ColorInterp=Gray
    Computed Min/Max=0.000,1.#IO
I've been converting the geotiff to AAIGrids and replace all "1.#INF" to my nodata value, but I'm hoping that there is an easier way to do this with GDAL.
Thanks in advance,
Bob
Robert Moskovitz
California Geological Survey
Seismic Hazards Zonation Program
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140402/8fda3bc5/attachment-0001.html>
