[gdal-dev] Set max value of "1.#IO" in Geotiff to nodata
Moskovitz, Bob@DOC Bob.Moskovitz at conservation.ca.gov
Wed Apr 2 12:18:15 PDT 2014
I've never seen "1.#IO" for max, but it is interesting that when this geotif was converted to an AAIGrids, it contained "1.#INF".  So this led me to conclude that I'm dealing with infinity.  I'll try what you using "-a_nodata inf" when I get the chance.
-Bob
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Wednesday, April 02, 2014 11:33 AM
To: gdal-dev at lists.osgeo.org
Cc: Moskovitz, Bob at DOC
Subject: Re: [gdal-dev] Set max value of "1.#IO" in Geotiff to nodata
Le mercredi 02 avril 2014 02:20:54, Moskovitz, Bob at DOC a écrit :
> Hello gdal,
> I have a set of geotiffs that have a strange max (infinity?) values
> that I would like to set to nodata.  These originally were netcdf
> files.  With the current of gdal in OSGEO4W, gdalinfo reports:
> gdalinfo -mm pola_cascadiad_sift2_maxspeed.tif
> Driver: GTiff/GeoTIFF
> Files: pola_cascadiad_sift2_maxspeed.tif
> Size is 1810, 1100
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (-118.302500000118700,33.779999999966194)
> Pixel Size = (0.000092592592580,-0.000092592592587)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-118.3025000,  33.7800000) (118d18' 9.00"W,
> 33d46'48.00"N)
> Lower Left  (-118.3025000,  33.6781481) (118d18' 9.00"W,
> 33d40'41.33"N)
> Upper Right (-118.1349074,  33.7800000) (118d 8' 5.67"W,
> 33d46'48.00"N)
> Lower Right (-118.1349074,  33.6781481) (118d 8' 5.67"W,
> 33d40'41.33"N)
> Center      (-118.2187037,  33.7290741) (118d13' 7.33"W, 33d43'44.67"N)
> Band 1 Block=1810x1 Type=Float64, ColorInterp=Gray
>     Computed Min/Max=0.000,1.#IO
> I've been converting the geotiff to AAIGrids and replace all "1.#INF"
> to my nodata value, but I'm hoping that there is an easier way to do
> this with GDAL.
With GDAL 1.10, you should be able to specify "-a_nodata inf".  But I'm not completely sure if 1.#IO is the represnetation of infinity. Might be a not-a- number ?
> Thanks in advance,
> Bob
> Robert Moskovitz
> California Geological Survey
> Seismic Hazards Zonation Program
> CONFIDENTIALITY NOTICE: This communication is intended only for the
> use of the individual or entity to which it is addressed. This message
> contains information from the State of California, California
> Geological Survey, which may be privileged, confidential and exempt
> from disclosure under applicable law, including the Electronic
> Communications Privacy Act. If the reader of this communication is not
> the intended recipient, you are hereby notified that any
> dissemination, distribution, or copying of this communication is strictly prohibited.
Geospatial professional services
http://even.rouault.free.fr/services.html
