[gdal-dev] DEFECT --without-libtool, somebody else?
David Tran david.tran at hsr.ch
Fri Apr 4 09:26:42 PDT 2014
> /bin/sh: /mingw/bin/ar: Bad file number
> make[1]: *** [/home/David/gdal-1.10.1/libgdal.a] Error 126
> make[1]: Leaving directory `/home/David/gdal-1.10.1'
> make: *** [check-lib] Error 2
-------- Original Message  --------
Subject: Re: [gdal-dev] DEFECT --without-libtool, somebody else?
From: Even Rouault <even.rouault at mines-paris.org>
To: David Tran <david.tran at hsr.ch>
Date: Friday, 4. April 2014 17:48:28
> What is the text or the error ?
>> Hi to everybody
>> I just tried to compile gdal (>=1.9.2) with --without-libtool flag and
>> it shows me with ./configure --without-libtool that it is not included
>> with a "no", but "make" ends sometime later with an ERROR.
>> Is there a fix or would somebody mind to verify the bug?
>> Cheers
>> David
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
