[gdal-dev] DEFECT --without-libtool, somebody else?
Even Rouault even.rouault at mines-paris.org
Fri Apr 4 10:44:05 PDT 2014
Le vendredi 04 avril 2014 18:26:42, David Tran a écrit :
> > /bin/sh: /mingw/bin/ar: Bad file number
> > make[1]: *** [/home/David/gdal-1.10.1/libgdal.a] Error 126
> > make[1]: Leaving directory `/home/David/gdal-1.10.1'
> > make: *** [check-lib] Error 2
oh mingw... Well it is probably a bad idea to try --without-libtool on a mingw
build.
> -------- Original Message  --------
> Subject: Re: [gdal-dev] DEFECT --without-libtool, somebody else?
> From: Even Rouault <even.rouault at mines-paris.org>
> To: David Tran <david.tran at hsr.ch>
> Date: Friday, 4. April 2014 17:48:28
> > What is the text or the error ?
> >> Hi to everybody
> >> I just tried to compile gdal (>=1.9.2) with --without-libtool flag and
> >> it shows me with ./configure --without-libtool that it is not included
> >> with a "no", but "make" ends sometime later with an ERROR.
> >> Is there a fix or would somebody mind to verify the bug?
> >> Cheers
> >> David
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Geospatial professional services
http://even.rouault.free.fr/services.html
