[gdal-dev] GML / NAS code redundancy
Even Rouault even.rouault at mines-paris.org
Sat Apr 5 13:10:46 PDT 2014
Martin,
> I will prepare such patch tomorrow.
Good
> ah, this seems to be much more better solution! It seems to work, I
> will do more tests later tomorrow.
Try to run the autotest/ogr/ogr_gml_read.py tests to check that it doesn't
cause regressions. And it would be good if you could add new test for your new
code
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
