[gdal-dev] Vagrant developement environment
Ivan Lucena lucena_ivan at hotmail.com
Sun Apr 6 09:39:42 PDT 2014
Hi Even,
I tried that out but got stuck on that error:
$ vagrant up
Bringing machine 'default' up with 'virtualbox' provider...
==> default: Clearing any previously set forwarded ports...
==> default: Clearing any previously set network interfaces...
==> default: Preparing network interfaces based on configuration...
    default: Adapter 1: nat
==> default: Forwarding ports...
    default: 80 => 8080 (adapter 1)
    default: 22 => 2222 (adapter 1)
==> default: Running 'pre-boot' VM customizations...
==> default: Booting VM...
==> default: Waiting for machine to boot. This may take a few minutes...
    default: SSH address: 127.0.0.1:2222
    default: SSH username: vagrant
    default: SSH auth method: private key
    default: Warning: Connection refused. Retrying...
The guest machine entered an invalid state while waiting for it
to boot. Valid states are 'starting, running'. The machine is in the
'aborted' state. Please verify everything is configured
properly and try again.
If the provider you're using has a GUI that comes with it,
it is often helpful to open that and watch the machine, since the
GUI often has more helpful error messages than Vagrant can retrieve.
For example, if you're using VirtualBox, run `vagrant up` while the
VirtualBox GUI is open.
I tried to load using the VirtualBox GUI but it didn't helped much
showing the message "Driver Kernel not installed (rc=-1908)" and "NS_ERROR_FAILURE".
Do you have any clue? My host is OSX 10.9 and VirtualBox is 4.3.8.
Regards,
Ivan
> From: even.rouault at mines-paris.org
> To: gdal-dev at lists.osgeo.org
> Date: Sun, 6 Apr 2014 00:09:38 +0200
> Subject: [gdal-dev] Vagrant developement environment
> Hi,
> Strongly inspired from MapServer vagrant set-up, itself strongly inspired from
> PDAL one, I've committed in trunk a Vagrantfile and the necessary scripts to
> setup a Vagrant development environment for GDAL.
> See http://trac.osgeo.org/gdal/wiki/Vagrant
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140406/ebd2469d/attachment.html>
