[gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
Volker Fröhlich volker27 at gmx.at
Sun Apr 6 10:26:57 PDT 2014
Hi!
Is "walk" compiled as soon as you enable odbc? I'm getting the following
compiler error on EL6:
/usr/bin/libtool --mode=compile --tag=CXX g++ -O2 -g -pipe -Wall
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mminimal-toc -fpic
-I/usr/include/libgeotiff  -Wall  -I.. -I../.. -I../generic -I../pgeo
-I/builddir/build/BUILD/gdal-1.11.0beta1/port
-I/builddir/build/BUILD/gdal-1.11.0beta1/gcore
-I/builddir/build/BUILD/gdal-1.11.0beta1/alg
-I/builddir/build/BUILD/gdal-1.11.0beta1/ogr
-I/builddir/build/BUILD/gdal-1.11.0beta1/ogr/ogrsf_frmts -DOGR_ENABLED
-I/usr/include/libgeotiff -I/builddir/build/BUILD/gdal-1.11.0beta1/port
-I/usr/include -Iexternal/include -I/usr/include/cfitsio  -c -o
../o/ogrwalktool.lo ogrwalktool.cpp
libtool: compile:  g++ -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
-fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64
-mminimal-toc -fpic -I/usr/include/libgeotiff -Wall -I.. -I../..
-I/builddir/build/BUILD/gdal-1.11.0beta1/ogr/ogrsf_frmts -I/usr/include
-DOGR_ENABLED -I/usr/include/libgeotiff
-I/builddir/build/BUILD/gdal-1.11.0beta1/port -I/usr/include
-Iexternal/include -I/usr/include/cfitsio -c vfkdatablock.cpp  -fPIC
-DPIC -o ../o/.libs/vfkdatablock.o
-I../generic -I../pgeo -I/builddir/build/BUILD/gdal-1.11.0beta1/port
ogrwalktool.cpp  -fPIC -DPIC -o ../o/.libs/ogrwalktool.o
libtool: compile:  g++ -c -DHAVE_LIBJPEG -DPCIDSK_INTERNAL -Isdk
-I/usr/include -Iexternal/include -I/usr/include/cfitsio -O2 -g -pipe
-Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
-I/usr/include/libgeotiff -Wall sdk/segment/cpcidskads40model.cpp -o
../o/cpcidskads40model.o >/dev/null 2>&1
../o/vfkdatablocksqlite.lo vfkdatablocksqlite.cpp
ogrwalktool.cpp: In function 'OGRErr Binary2WkbMGeom(unsigned char*&,
WKBGeometry*, int)':
ogrwalktool.cpp:256: error: no match for 'operator[]' in
'*((geom->WKBGeometry::<anonymous>.WKBGeometry::<anonymous
union>::linestring.LineString::segments + ((long unsigned int)(((long
unsigned int)i) * 16ul)))->CurveSegment::points + ((long unsigned
int)(((long unsigned int)j) * 24ul)))[count]'
make[3]: *** [../o/ogrwalktool.lo] Error 1
It builds fine in Fedora Rawhide.
Greetings,
Volker
> -------- Original Message  --------
> Subject: [gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
> From: Even Rouault <even.rouault at mines-paris.org>
> To: gdal-dev at lists.osgeo.org dev <gdal-dev at lists.osgeo.org>
> Date: Friday, 4. April 2014 22:19:48
>> Hi,
>> I have prepared a GDAL/OGR 1.11.0 first beta release. The source
>> archives can be found at :
>> http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.gz
>> http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.xz
>> http://download.osgeo.org/gdal/1.11.0/gdal1110beta1.zip
>> The NEWS for the release can be found at the top of:
>> http://svn.osgeo.org/gdal/trunk/gdal/NEWS
>> As usual, you are warmly invited to test and report (ideally with
>> patches) anything that must be fixed before the release :
>> http://trac.osgeo.org/gdal/
>> There will be perhaps another beta, but if things go smoothly, the
>> next step will be RC1 (let's say end of next week).
>> Note: due to the current unavailability of gdal.org, which is the
>> machine on which releases are usually prepared, I've created the
>> snapshot on my PC. Hopefully this will have no consequence on the
>> above archives.
>> Best regards,
>> Even
> gdal-dev mailing list
