[gdal-dev] Vagrant developement environment
Ivan Lucena lucena_ivan at hotmail.com
Sun Apr 6 12:20:48 PDT 2014
> The error messages seems to indicate this is an issue with your VirtualBox
> setup. And is your host a 64bit OS ?
Yes, I recently took advantage of Apple free updated, going from 10.6-32 to 10.9-64 and I have others Linux 64 bit running on VirtualBox without problems.
$ uname -a
Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.90.20~2/RELEASE_X86_64 x86_64
What version of VirtualBox did you use to create the gdal-vagrant?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140406/c47bfcfd/attachment.html>
