[gdal-dev] Build failed
Even Rouault even.rouault at mines-paris.org
Sun Apr 6 13:32:28 PDT 2014
Le dimanche 06 avril 2014 22:28:43, Yves Jacolin a écrit :
> Hello,
> I have a failure with gdal (still using gdal git repository):
> /usr/bin/ld: /usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o:
> relocation R_X86_64_32S against `_ZTV14AAIGRasterBand' can not be used when
> making a shared object; recompile with -fPIC
> /usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o: error adding
> symbols: Bad value
> collect2: error: ld returned 1 exit status
> make[1]: *** [libgdal.la] Erreur 1
> make[1]: quittant le répertoire « /usr/local/src/gdal/gdal »
> make: *** [check-lib] Erreur 2
Hum, strange. Perhaps do a make clean before rebuilding ?
> any idea?
> Y.
Geospatial professional services
http://even.rouault.free.fr/services.html
