[gdal-dev] Build failed
Yves Jacolin yjacolin at free.fr
Sun Apr 6 13:44:50 PDT 2014
Le dimanche 6 avril 2014, 22:32:28 Even Rouault a écrit :
> Le dimanche 06 avril 2014 22:28:43, Yves Jacolin a écrit :
> > Hello,
> > I have a failure with gdal (still using gdal git repository):
> > /usr/bin/ld: /usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o:
> > relocation R_X86_64_32S against `_ZTV14AAIGRasterBand' can not be used
> > when
> > making a shared object; recompile with -fPIC
> > /usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o: error adding
> > symbols: Bad value
> > collect2: error: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Erreur 1
> > make[1]: quittant le répertoire « /usr/local/src/gdal/gdal »
> > make: *** [check-lib] Erreur 2
> Hum, strange. Perhaps do a make clean before rebuilding ?
> > any idea?
> > Y.
it seems working much better after a make clean ;) the last failure with Mysql
flag could explain this.
Thanks,
Y.
Yves Jacolin
