[gdal-dev] Vagrant developement environment
Even Rouault even.rouault at mines-paris.org
Mon Apr 7 01:07:58 PDT 2014
Selon Ivan Lucena <lucena_ivan at hotmail.com>:
> > > What version of VirtualBox did you use to create the gdal-vagrant?
> > I don't think my own version of VirtualBox (4.2.12) has much impact.
> There's
> > nothing from it in the text files that define the gdal-vagrant
> configuration
> I have had the experience that by exporting a VM as appliance on a newer
> version of that software I could not successfully import and start the VM on
> an older version.
> That is OK.
Hum, the base VM used by the Vagrantfile is
http://files.vagrantup.com/precise64.box . I've used the same one as MapServer
and PDAL. And apparently Howard is using a Mac as a host...
Even
