[gdal-dev] Vagrant developement environment
Ivan Lucena lucena_ivan at hotmail.com
Mon Apr 7 03:46:29 PDT 2014
I've got it to work. But I could not follow your instructions.
$ vagrant ssh
Welcome to Ubuntu 12.04 LTS (GNU/Linux 3.2.0-23-generic x86_64)
 * Documentation:  https://help.ubuntu.com/
Welcome to your Vagrant-built virtual machine.
Last login: Mon Apr  7 04:24:23 2014 from 10.0.2.2
vagrant at gdal-vagrant:~$ ls
postinstall.sh
vagrant at gdal-vagrant:~$ ls -a
.   .bash_history  .bashrc  .gem            .profile  .sudo_as_admin_successful  .veewee_version
..  .bash_logout   .cache   postinstall.sh  .ssh      .vbox_version
vagrant at gdal-vagrant:~$ gdalinfo --version
The program 'gdalinfo' is currently not installed.  You can install it by typing:
sudo apt-get install gdal-bin
There is no gdal/gdal folder. I ran that "sudo sh posinstall.sh" wish install a development environment but that was supposed to run automatically. Right? Maybe something got timed out.
> Date: Mon, 7 Apr 2014 10:07:58 +0200
> From: even.rouault at mines-paris.org
> To: lucena_ivan at hotmail.com
> CC: even.rouault at mines-paris.org; gdal-dev at lists.osgeo.org; hobu.inc at gmail.com
> Subject: RE: [gdal-dev] Vagrant developement environment
> Selon Ivan Lucena <lucena_ivan at hotmail.com>:
> > > > What version of VirtualBox did you use to create the gdal-vagrant?
> > > I don't think my own version of VirtualBox (4.2.12) has much impact.
> > There's
> > > nothing from it in the text files that define the gdal-vagrant
> > configuration
> > I have had the experience that by exporting a VM as appliance on a newer
> > version of that software I could not successfully import and start the VM on
> > an older version.
> > That is OK.
> Hum, the base VM used by the Vagrantfile is
> http://files.vagrantup.com/precise64.box . I've used the same one as MapServer
> and PDAL. And apparently Howard is using a Mac as a host...
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140407/962291e3/attachment.html>
