[gdal-dev] Vagrant developement environment
Ivan Lucena lucena_ivan at hotmail.com
Mon Apr 7 21:49:36 PDT 2014
Hi Howard,
I started it all over and I got it to work.
When I logged with "vagrant ssh" this time the gdal folder was there but not installed yet.
And I didn't have development tools build GDAL, so I run "sudo sh posinstall.sh" and I also installed "make" and "perl" by hand and after that I got a clean GDAL installation.
Ha, I also needed to install the GDAL-Python "by hand".
I can see that it could be a nice environment to run GDAL autotest, if I could add some SDK dependent driver.
What else can we do with that thing? How does PDAL take advantage of Vagrant anyway?
Ivan
> From: howard at hobu.co
> Date: Mon, 7 Apr 2014 11:09:09 -0500
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Vagrant developement environment
> On Apr 7, 2014, at 5:57 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
> > vagrant provision
> If you get stuck with vagrant, on prescribed chicken-waving exercise is to simply do 'vagrant destroy' of the vm and then 'vagrant up' again. 'vagrant provision' will still have the effects of partially Maybe some prerequisite didn't couldn't be built because of network access or something.
> gdal-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/gdal-dev√√
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140408/a0489640/attachment.html>
