[gdal-dev] [EXTERNAL] Gdal 1.10.1 with OCI and ODBC doesn't compile right
Ivan Lucena lucena_ivan at hotmail.com
Tue Apr 8 07:04:40 PDT 2014
David,
In order to compile the two Oracle driver you need to have in your system an OCI SDK installation appropriated for that plataform/environment. Here are the avaible downloads for Oracle Instant Client:
http://www.oracle.com/technetwork/database/features/instant-client/index-097480.html?ssSourceSiteId=ocomen
Wish one are you trying to use?
Regards,
Ivan
> Date: Tue, 8 Apr 2014 09:44:37 +0200
> From: david.tran at hsr.ch
> To: Michael.Smith at erdc.dren.mil; gdal-dev at lists.osgeo.org
> CC: sfkeller at hsr.ch
> Subject: Re: [gdal-dev] [EXTERNAL] Gdal 1.10.1 with OCI and ODBC doesn't compile right
> Hi Mike
> I created these symlinks and
> --with-oci-include=/instantclient/sdk/include finds whatever it needs,
> but --with-oci-lib=/instantclient doesn't.
> Cheers
> David
> -------- Original Message --------
> Subject: Re: [EXTERNAL] [gdal-dev] Gdal 1.10.1 with OCI and ODBC doesn't
> compile right
> From: Smith, Michael ERDC-RDE-CRREL-NH <Michael.Smith at erdc.dren.mil>
> To: David Tran <david.tran at hsr.ch>, gdal-dev at lists.osgeo.org
> <gdal-dev at lists.osgeo.org>
> Date: Monday, 7. April 2014 20:33:31
> > David,
> > For using OCI with GDAL and --with-oci-lib, you need both oci-lib and
> > oci-include
> > For example:
> > --with-oci-include=/home/oracle/local/instantclient_11_2
> > --with-oci-lib=/home/oracle/local/instantclient_11_2
> > And for the lib, you need to symlink
> > libclntsh.so.11.x -> libclntsh.so
> > libocci.so.11.x -> libocci.so
> > Mike
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140408/aa752b95/attachment.html>
