[gdal-dev] Import .GDB into MSSQL Server database
Jan Heckman jan.heckman at gmail.com
Tue Apr 8 15:47:13 PDT 2014
Depends on the geodatabase version.
If (AG) 10, there is a ogr driver for it, so you would not need shapefiles
and avoid losing long fieldnames etc.
There is no driver for earlier AG/gdb versions.
Maybe it's an old
thread<http://gis.stackexchange.com/questions/910/file-geodatabase-open-api>,
but it has some information.
Integration in ogr <http://www.gdal.org/ogr/drv_filegdb.html>.
good luck,
Jan
On Tue, Apr 8, 2014 at 8:44 PM, cdp <cdaponte at synergyaspen.ca> wrote:
> Any ideas on how to import a .GDB into MSSQL Server database without
> converting to a .shp first?
> Thanks all!
> C
> http://osgeo-org.1560.x6.nabble.com/Import-GDB-into-MSSQL-Server-database-tp5133917.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140409/fd652ca6/attachment.html>
