[gdal-dev] Import .GDB into MSSQL Server database
Kyle Shannon kyle at pobox.com
Tue Apr 8 15:52:38 PDT 2014
On Tue, Apr 8, 2014 at 4:47 PM, Jan Heckman <jan.heckman at gmail.com> wrote:
> Depends on the geodatabase version.
> If (AG) 10, there is a ogr driver for it, so you would not need shapefiles
> and avoid losing long fieldnames etc.
> There is no driver for earlier AG/gdb versions.
OpenFileGDB should handle earlier versions, read only:
http://gdal.org/ogr/drv_openfilegdb.html
It's in the trunk.
> Maybe it's an old thread, but it has some information.
> Integration in ogr.
> good luck,
> Jan
> On Tue, Apr 8, 2014 at 8:44 PM, cdp <cdaponte at synergyaspen.ca> wrote:
>> Any ideas on how to import a .GDB into MSSQL Server database without
>> converting to a .shp first?
>> Thanks all!
>> C
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Import-GDB-into-MSSQL-Server-database-tp5133917.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Kyle
