[gdal-dev] Vagrant developement environment
Even Rouault even.rouault at mines-paris.org
Wed Apr 9 10:09:01 PDT 2014
Le mercredi 09 avril 2014 19:01:55, Ari Jolma a écrit :
> On 04/09/2014 05:49 PM, Even Rouault wrote:
> > Le mardi 08 avril 2014 06:49:36, Ivan Lucena a écrit :
> >> Hi Howard,
> >> I started it all over and I got it to work.
> >> When I logged with "vagrant ssh" this time the gdal folder was there but
> >> not installed yet.
> >> And I didn't have development tools build GDAL, so I run "sudo sh
> >> posinstall.sh" and I also installed "make" and "perl" by hand and after
> >> that I got a clean GDAL installation.
> >> Ha, I also needed to install the GDAL-Python "by hand".
> > When rebuilding from scratch, I could see that there was indeed an issue
> > with Perl bindings. I've disabled them. So "vagrant up" show work OK
> May I ask, what was this issue?
I didn't really investigate. Likely "make generate" not done when you build
from a fresh svn checkout.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
