[gdal-dev] [EXTERNAL] oci and oracle express 11
Mateusz Łoskot mateusz at loskot.net
Thu Apr 10 03:30:44 PDT 2014
On 10 April 2014 11:27, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2014-04-10 3:27 GMT+02:00 Smith, Michael ERDC-RDE-CRREL-NH
> <Michael.Smith at erdc.dren.mil>:
>> If <user>/<passwd>@xe works in sqlplus, you can use that in OGR. Its using
>> the same libs to connect.
>> Try ogrinfo -ro OCI:<user>/<passwd>@xe
> I already tried that but without success...
> ERROR 1: ORA-12154: TNS:could not resolve the connect identifier specified
>  in <unnamed>
Try easy connection mode with
username/password at 127.0.0.1:1521/xe
Also, check you are using the same type of binaries (32 or 64 bit) of
GDAL/OGR and InstantClient. AFAIR, they don't mix.
Also, for development purposes, I usually replace hostname with IP address
in tnsnames.ora, as the name resolving proved troublesome for me.
Best regards,
Mateusz  Łoskot, http://mateusz.loskot.net
