[gdal-dev] ogr2ogr ERROR 6: No translation
Jason Mathis jmathis at redzonesoftware.com
Thu Apr 10 08:13:38 PDT 2014
Hi All,
thanks for the responses.
I believe my extents are:
(-120.00591219477626, -114.03946520116759, 35.00247168585889, 42.00234483532862)
$ ogr2ogr version is:
GDAL 1.10.1, released 2013/08/26
I not sure how to find the proj4 version. Is it this?
$ proj --version
Rel. 4.8.0, 6 March 2012
thanks again!
On April 9, 2014 at 10:22:13 PM, xavier lhomme (lhomme.xavier at gmail.com) wrote:
Hi
You should specify the version of gdal you are using (and proj4 too).
Sometimes ago I used NGA Geotrans to perform GeoId conversion. But recent version of proj4 are able to perform such conversion.
Le 10 avr. 2014 06:11, "Andre Joost" <andre+joost at nurfuerspam.de> a écrit :
Am 10.04.2014 04:31, schrieb Jason Mathis:
Hi All,
On to the next problem:) I discovered today that I need to reproject
the shape file before rasterizing it. I get the below error.
Any ideas? Is it not possible?
What extent does your shapefile have?
Some projections are limited to the visible half of the globe.
HTH,
André Joost
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This transmission contains confidential and privileged information intended
solely for the party identified above. If you receive this message in
error, you must not use it or convey it to others. Please destroy it
immediately and contact the sender at (303) 386-3955 or by return e-mail to
the sender.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140410/a4577aaa/attachment.html>
