[gdal-dev] ogr2ogr ERROR 6: No translation
Jason Mathis jmathis at redzonesoftware.com
Thu Apr 10 10:41:48 PDT 2014
Awesome Andre!
That will work. So I guess it is possible.
many thanks,
jason
On April 10, 2014 at 9:38:00 AM, Andre Joost (andre+joost at nurfuerspam.de) wrote:
Am 10.04.2014 17:13, schrieb Jason Mathis:
> Hi All,
> thanks for the responses.
> I believe my extents are:
> (-120.00591219477626, -114.03946520116759, 35.00247168585889, 42.00234483532862)
This sounds reasonable for Nevada.
> $ ogr2ogr version is:
> GDAL 1.10.1, released 2013/08/26
> I not sure how to find the proj4 version. Is it this?
> $ proj --version
> Rel. 4.8.0, 6 March 2012
Both are be up to date.
You can simplify your command line to:
ogr2ogr -s_srs epsg:4326 -t_srs epsg:5070 Nevada_Albers.shp Nevada-WGS84.shp
I don't get error messages with a point shapefile built from your extent
coordinates.
HTH,
André Joost
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This transmission contains confidential and privileged information intended
solely for the party identified above. If you receive this message in
error, you must not use it or convey it to others. Please destroy it
immediately and contact the sender at (303) 386-3955 or by return e-mail to
the sender.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140410/5f61e9bc/attachment.html>
