[gdal-dev] gdal_retile x64 : No input files selected.
Imran Rajjad rajjad at gmail.com
Fri Apr 11 00:15:42 PDT 2014
Hi list,
I am using GDAL 10.1 x64 with Python 2.7.5 x64
It seems python script is not able to find the input file
W:\>gdal_retile.py -v -r -levels 4 -ps 2048 2048 -co "TILED=YES" -co
"COMPRESS=JPEG" -targetDir w:\dem\dem_pyramid w:\dem\dem.tif
2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
Usage: gdal_retile.py
        [-v] [-co NAME=VALUE]* [-of out_format]
        [-ps pixelWidth pixelHeight]
        [-ot  {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
               CInt16/CInt32/CFloat32/CFloat64}]
        [ -tileIndex tileIndexName [-tileIndexField fieldName]]
        [ -csv fileName [-csvDelim delimiter]]
        [-s_srs srs_def]  [-pyramidOnly] -levels numberoflevels
        [-r {near/bilinear/cubic/cubicspline/lanczos}]
        [-useDirForEachRow]
        -targetDir TileDirectory input_files
Can somebody tell me what is wrong with the command
below is GDAL info of the geotiff file
---GDALINFO------
W:\>gdalinfo dem\dem.tif
Driver: GTiff/GeoTIFF
Files: dem\dem.tif
       dem\dem.tif.aux.xml
Size is 30001, 24001
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (59.999583333323244,40.000416763514124)
Pixel Size = (0.000833333333333,-0.000833333333333)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  59.9995833,  40.0004168) ( 59d59'58.50"E, 40d 0' 1.50"N)
Lower Left  (  59.9995833,  19.9995834) ( 59d59'58.50"E, 19d59'58.50"N)
Upper Right (  85.0004167,  40.0004168) ( 85d 0' 1.50"E, 40d 0' 1.50"N)
Lower Right (  85.0004167,  19.9995834) ( 85d 0' 1.50"E, 19d59'58.50"N)
Center      (  72.5000000,  30.0000001) ( 72d30' 0.00"E, 30d 0' 0.00"N)
Band 1 Block=30001x1 Type=Int16, ColorInterp=Gray
  Description = Layer_1
  Min=-32768.000 Max=8469.000
  Minimum=-32768.000, Maximum=8469.000, Mean=-339.616, StdDev=7609.851
  NoData Value=0
  Metadata:
    LAYER_TYPE=athematic
STATISTICS_HISTOBINVALUES=35892220|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|147192240|103498980|58861348|42041116
|24849760|20456436|19853444|32923904|23568064|14391364|11251344|9393020|9059076|
8846812|7765888|6834360|6443632|6328036|5700032|5445180|5022004|4646148|4389944|
4296656|4444024|4944940|5610800|6424704|8513544|9714796|11723868|13505128|117576
68|8901568|6243536|4127656|2605304|1385800|671944|286624|116272|41912|27716|1352
0|10816|5408|4056|2028|676|0|0|0|676|
    STATISTICS_HISTOMAX=8469
    STATISTICS_HISTOMIN=-32768
    STATISTICS_HISTONUMBINS=256
    STATISTICS_MAXIMUM=8469
    STATISTICS_MEAN=-339.61644644564
    STATISTICS_MEDIAN=414.8984375
    STATISTICS_MINIMUM=-32768
    STATISTICS_MODE=-68.34765625
    STATISTICS_SKIPFACTORX=26
    STATISTICS_SKIPFACTORY=26
    STATISTICS_STDDEV=7609.8514119626
regards,
Imran
I.R
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140411/07066684/attachment.html>
