[gdal-dev] [ogr2ogr 1.10]EPSG 3943
Rémy GOURRAT rgourrat at ag-carto.fr
Fri Apr 11 09:46:35 PDT 2014
At the end of my command line ogr2ogr, i Try to attribute a SRS output with this syntax :
-a_srs EPSG:3946
But every time I have this message :
ERROR 6: EPSG PCS/GCS code 3946 not found in EPSG support files.  Is this a valid EPSG coordinate system?
Failed to process SRS definition: EPSG:3946
I check the pcs.csv and i get the line 3946 with the SRS def
pcs.csv is in the same directory that ogr2ogr
I forget something ?
Thanks for your help
Rémy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140411/30482b87/attachment.html>
