[gdal-dev] Problems with large ASTER GeoTIFF
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Apr 15 04:58:11 PDT 2014
Nicole,
The problem is reading the source file itself. GDAL is unable to find any
valid pixels. Check if you are using the latest GDAL binaries. Use
"gdalinfo -version". Use qgis to view the input and output. GIMP can't
handle anything except basic pixel types. The -mm option should find some
valid pixels if everything is good.
Later, you should scale the pixel values to 0-255 range to represent them
in PNG.
Best regards,
Chaitanya Kumar CH
On 15-Apr-2014 4:40 pm, "Nicole Stoffels" <stoffels at f2e.de> wrote:
> Thank you both for your answers. I have applied your suggestions.
> Making a single command works but does not change the result.
> Concerning the compression, I used LZW instead of NONE. However, it also
> does not make any difference.
> I also changed the srcwin parameters. I do not get any errors and the
> gdalinfo says that the subarea is within the original area.
> I skipped the png part to make it easier first. And after trying to open
> the new tif with gimp and getting an error message that the float32 data
> cannot be displayed I added the ot-flag. Here is my new command line:
> $ gdal_translate -ot Byte -srcwin 0 0 4000 4000 -co COMPRESS=LZW
> EUD_CP-DEMS_6500035000-AA.tif test.tif
> What I get is a completely black tif. Here are the two gdalinfo-outputs,
> that I get:
> $ gdalinfo -mm EUD_CP-DEMS_6500035000-AA.tif
> Driver: GTiff/GeoTIFF
> Files: EUD_CP-DEMS_6500035000-AA.tif
> Size is 40000, 40000
> Coordinate System is:
> PROJCS["ETRS89 / ETRS-LAEA",
>     GEOGCS["ETRS89",
>         DATUM["European_Terrestrial_Reference_System_1989",
>             SPHEROID["GRS 1980",6378137,298.2572221000027,
>                 AUTHORITY["EPSG","7019"]],
>             AUTHORITY["EPSG","6258"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4258"]],
>     PROJECTION["Lambert_Azimuthal_Equal_Area"],
>     PARAMETER["latitude_of_center",52],
>     PARAMETER["longitude_of_center",10],
>     PARAMETER["false_easting",4321000],
>     PARAMETER["false_northing",3210000],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","3035"]]
> Origin = (6000000.000000000000000,4000000.000000000000000)
> Pixel Size = (25.000000000000000,-25.000000000000000)
> Metadata:
>   TIFFTAG_DOCUMENTNAME=EUD_CP-DEMS_6500035000-AA.tif
>   TIFFTAG_IMAGEDESCRIPTION=File written by egcs_wrgtif 2.1
>   TIFFTAG_SOFTWARE=IDL 8.2, Exelis Visual Information Solutions, Inc.
>   TIFFTAG_DATETIME=2013:09:17 21:00:27
>   TIFFTAG_XRESOLUTION=100
>   TIFFTAG_YRESOLUTION=100
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   COMPRESSION=LZW
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  ( 6000000.000, 4000000.000) ( 37d47'0.49"E, 56d 7'28.33"N)
> Lower Left  ( 6000000.000, 3000000.000) ( 32d47'35.21"E, 47d45'16.08"N)
> Upper Right ( 7000000.000, 4000000.000) ( 51d32'27.75"E, 51d55'27.24"N)
> Lower Right ( 7000000.000, 3000000.000) ( 44d57'3.39"E, 44d18'11.63"N)
> Center      ( 6500000.000, 3500000.000) ( 41d41'39.51"E, 50d15'46.40"N)
> Band 1 Block=40000x1 Type=Float32, ColorInterp=Gray
> ERROR 1: Failed to compute min/max, no valid pixels found in sampling.
> $ gdalinfo -mm test.tif
> Files: test.tif
> Size is 4000, 4000
>     GEOGCS["ETRS89",
>             SPHEROID["GRS 1980",6378137,298.2572221010002,
>     UNIT["metre",1,
> Metadata:
>   AREA_OR_POINT=Area
>   COMPRESSION=LZW
>   INTERLEAVE=BAND
> Corner Coordinates:
> Lower Left  ( 6000000.000, 3900000.000) ( 37d10'18.23"E, 55d18'7.26"N)
> Upper Right ( 6100000.000, 4000000.000) ( 39d16'14.71"E, 55d46'30.54"N)
> Lower Right ( 6100000.000, 3900000.000) ( 38d38'6.52"E, 54d57'38.92"N)
> Center      ( 6050000.000, 3950000.000) ( 38d12'51.64"E, 55d32'35.70"N)
> Band 1 Block=4000x2 Type=Byte, ColorInterp=Gray
>     Computed Min/Max=0.000,0.000
> Am 14.04.2014 19:51, schrieb Etienne Tourigny:>
>> On Mon, Apr 14, 2014 at 11:16 AM, Nicole Stoffels <stoffels at f2e.de
>> <mailto:stoffels at f2e.de>> wrote:
>>     Dear Gdal-List,
>>     I have a large ASTER file (downloaded from
>>     http://www.eea.europa.eu/data-__and-maps/data/eu-dem#tab-__
>> european-data
>>     <http://www.eea.europa.eu/data-and-maps/data/eu-dem#tab-european-data
>>     in the GeoTIFF-format. It is compressed with LZW. What I want to do
>> is:
>>     1. unpack it
>>     2. seperate a smaller region from it
>>     3. convert this regional GeoTIFF to a PNG
>>     What I am doing:
>>     $ gdal_translate -co COMPRESS=NONE EUD_CP-DEMS_6500035000-AA.tif
>>     tmp1.tif
>>     $ gdal_translate -srcwin 6500 3300 1000 1000 tmp1.tif tmp2.tif
>>     When I display the info with gdalinfo the first step seems to
>>     produce a decompressed file. The line COMPRESSION=LZW is not there
>>     anymore.
>> You need to set the compression options on any gdal command, it does not
>> use the compression of the input file. Also, you specifically asked for
>> no compression, so it's doing what you told it to.
>> use "-co COMPRESS=LZW"
>>     However, if I want to display the min and max with gdalinfo, I get
>>     the following error.
>> try without changing the extents and see if a single command (as
>> suggested by Jean-Luc) works
>>     I thought that the file might be too large, but if I change the
>>     data_type from float 32 to e.g. Int16 I get 0 as min and max value.
>>     That's why I assume that already the first gdal_translate does not
>>     work as I actually want it to work.
>> your input values are probably between 0 and 1 in this case
>>     The other two transformations work without error messages. However,
>>     in the end I get a black png.
>>     I have tried all types of transformation with various options. But
>>     as I am new in the subject and do not know much about gdal, I have
>>     no further ideas how to generate a file from my large GeoTIFF to
>>     continue working with.
>>     I hope someone has an idea, what's going wrong with my
>>     gdal_translations. Thanks very much in advance.
>>     Best regards
>>     Nicole
>>     _________________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/__mailman/listinfo/gdal-dev
>>     <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140415/5325da62/attachment-0001.html>
