[gdal-dev] OCI driver and setting the client encoding
Martin Landa landa.martin at gmail.com
Tue Apr 15 13:47:54 PDT 2014
2012-09-20 20:06 GMT+02:00 Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
>> So, if I understood it, you are using ogr2ogr in a Finnins-Finland
> Windows locale but Oracle is set for
>> american.america and the OGR/OCI driver doesn't make the distinction
> automatically.
I had similar problem, I noticed that with Oracle 11g EX works with
set NLS_LANG=american_america.UTF8
(note an underscore, not a dot). Are you sure that your syntax is
correct? It can be that Oracle is changing it on its own.
It would be really helpful to document it on driver page. I will try
to put there at least a small note about that in the next days. Martin
