[gdal-dev] Problems with large ASTER GeoTIFF
Joaquim Luis jluis at ualg.pt
Wed Apr 16 04:24:04 PDT 2014
Thanks, did not know that. But since both products were originally 2
bytes ints, the mix can also be scaled to 2 bytes without loss of
original precision.
> EUDEM is an "hybrid product based on SRTM and ASTER GDEM data fused by
> a weighted averaging approach"
> Le 2014-04-15 19:55, Joaquim Luis a écrit :
>> but the ASTER grids have lower real resolution than the SRTM (despite
>> being distributed as 1 arc sec grids) and the later are originally
>> int16 , so scaling to 2 bytes ints should be OK.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
