[gdal-dev] simplifying height contours
Even Rouault even.rouault at mines-paris.org
Wed Apr 16 05:34:06 PDT 2014
Le mercredi 16 avril 2014 12:46:45, Vincent Mora a écrit :
> Hi,
> I have a vector file with height contours and I need to simplify the
> lines (too many points).
> Isolevel lines must not intersect, so simplifying the vector directly is
> a bit tedious (involves collision detection of lines to constrain
> simplification).
> If I had the DEM, I could reduce the resolution and use
> gdal_countour...but I don't.
> So what about generating the DEM from the height contours? Do you think
> it fits in gdal somewhere ? Has someone the same kind of use-case ?
It already exists in fact:
- gdal_rasterize : will produce a DEM with the contour line stroked, and with
holes between them
- gdal_fillnodata.py : will fill the holes with interpolated values
> V.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
