[gdal-dev] ogr2ogr -f OCI fails on Windows
Martin Landa landa.martin at gmail.com
Wed Apr 16 10:17:31 PDT 2014
Hi all,
when trying to convert selected GML layer to Oracle spatial
ogr2ogr -f OCI oci:user/passwd data\20140331_OB_564729_UKSH.xml.gz
StavebniObjekty -overwrite -lco srid=2065
the command fails with
Podpis problému:
  Název události problému:    APPCRASH
  Název aplikace:    ogr2ogr.exe
  Verze aplikace:    0.0.0.0
  Časové razítko aplikace:    534e730f
  Název chybného modulu:    kernel32.dll
  Verze chybného modulu:    6.0.6002.19034
  Časové razítko chybného modulu:    52f2ecb1
  Kód výjimky:    c0000005
  Posun výjimky:    0001e743
  Verze operačního systému:    6.0.6002.2.2.0.274.10
  ID národního prostředí:    1029
  Další informace 1:    f931
  Další informace 2:    90179027e379dba7ee23240ddb71d080
  Další informace 3:    aad6
  Další informace 4:    c968bb9711c76b26ad52f41a001dfb9d
Debug:
Warning 6: Can't create field DetailniTEAKod with type IntegerList on
Oracle layers.  Creating as VARCHAR.
OCI: Prepare(ALTER TABLE STAVEBNIOBJEKTY ADD "DetailniTEAKod" VARCHAR(2047))
GML: ResetReading()
GML: ResetReading()
OCI: Prepare(INSERT INTO
"STAVEBNIOBJEKTY"("OGR_FID","gml_id","Kod","Nespravny","CisloDomovni","IdentifikacniParcelaId","TypStavebnihoObjektuKod","ZpusobVyuzitiKod","CastObceK
od","MomcKod","PlatiOd","PlatiDo","IdTransakce","GlobalniIdNavrhuZmeny","IsknBudovaId","Dokonceni","DruhKonstrukceKod","ObestavenyProstor","PocetBytu","PocetPodlazi","Podlahov
aPlocha","PripojeniKanalizaceKod","PripojeniPlynKod","PripojeniVodovodKod","VybaveniVytahemKod","ZastavenaPlocha","ZpusobVytapeniKod","ZpusobOchranyKod","ZpusobOchranyTypOchra
nyKod","ZpusobOchranyIdTransakce","ZpusobOchranyRizeniId","DetailniTEAKod")
VALUES ( :fid ,  :field_0,  :field_1,  :field_2,  :field_3,  :field_4,
 :field_5,  :field_6,  :fiel
d_7,  :field_8,  :field_9,  :field_10,  :field_11,  :field_12,
:field_13,  :field_14,  :field_15,  :field_16,  :field_17,  :field_18,
 :field_19,  :field_20,  :field_21,  :fi
eld_22,  :field_23,  :field_24,  :field_25,  :field_26,  :field_27,
:field_28,  :field_29,  :field_30) )
OCI: Prepare(SELECT MAX("OGR_FID") FROM "STAVEBNIOBJEKTY")
Any idea? Thanks in advance! Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
