[gdal-dev] GDAL/OGR 1.11.0 Release Candidate 1 available for testing
Wolf Bergenheim wolf+grass at bergenheim.net
Thu Apr 17 08:20:20 PDT 2014
On Thu, Apr 17, 2014 at 3:01 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> > I suppose, but the problem is that without it the whole thing becomes
> > useless for large datasets (> 100k features) due to GME restrictions. I
> > just thought that it would be good to have a GME driver that works on
> those
> > large tables too. :)
> The problem is that at some point we must take a snapshot and say "hey,
> this is
> GDAL 1.11, the latest and greatest, use it please". I think it is OK if new
> drivers are still a bit experimental.
Ok, no need for it then. Do you want me to roll my changes back from the
1.11 branch or apply my patch to it?
> Reviewing the commit, I think that it has at least one issue because
> SetSpatialFilter() will segfault in switch( poGeomIn->getGeometryType() )
> if
> passed a NULL geometry, which is perfectly legal, in order to uninstall a
> spatial filter.
> Did you test the driver with the test_ogrsf utility ? (cd apps; make
> test_ogrsf)
Noo :( I was too tired and forgot. I only ran my own python test which
doesn't try to unset the spatial filter. Will need to add that test later.
Anyways just committed a fix for the crash and now test_ogrsf works mostly.
A few errors, but nothing that causes a crash. They are mostly GME -related
things, like the it doesn't support infinity and big numbers. So will add a
check for that later.
--Wolf
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140417/34032289/attachment-0001.html>
