[gdal-dev] GDAL/OGR 1.11.0 Release Candidate 1 available for testing
Jeremy Palmer JPalmer at linz.govt.nz
Thu Apr 17 23:03:59 PDT 2014
I've just been testing GDAL/OGR 1.11.0 and the MBTiles driver does not seem to be reading transparency information. Not sure if this is new to 1.11.0 or was an issue there before. Ticket here:
http://trac.osgeo.org/gdal/ticket/5439
Cheers,
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
