[gdal-dev] Help request to make Python bindings to build again with MacOS X 10.9
Even Rouault even.rouault at mines-paris.org
Sun Apr 20 02:39:59 PDT 2014
> Well, you could try leaving out the os.uname test.  clang is clang no matter
> what version of OS X, and it wouldn't hurt to include the option when it's
> already default.  Also, testing the OS version doesn't necessarily say what
> clang version is installed.
Could you try leaving out test os.uname test ? It is inspired from the link I
found where they say that clang began the default compiler with Darwin >= 11.
Ideally we shouldn't break building for folks using GCC.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with
> hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket
> filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
