[gdal-dev] problem with gdal_translate jp2 file from the usgs (linux)
Kasper van Wijk k.vanwijk at auckland.ac.nz
Thu Apr 24 14:29:03 PDT 2014
thank you, Even, for the fast reply. I am a beginner at GDAL and installed
the gdal suite with "standard" apt-get and yum, respectively. Can you point
me to a place where I can read how to compile GDAL against one of the other
JPEG2000 libraries, as you say?
Thanks again,
Kasper
On 25 April 2014 09:25, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le jeudi 24 avril 2014 23:17:29, Kasper van Wijk a écrit :
> > dear all,
> > I am downloading jp2 data from the usgs national map. To plot this in
> > cartopy, I need to transform to something else, such as geotiff. However,
> > using gdal_translate I get a warning copied below, and the output is a
> > grainy bw version of the image. I have checked my results under linux
> both
> > fedora core 20 and ubuntu 12.04 versions with GDAL 1.7.3, released
> > 2010/11/10
> > gdal_translate m_3810623_ne_13_1_20110921_20111031.jp2 test.tiff -of
> GTiff
> > warning: not enough tile data (2 bytes)
> Apparently your GDAL build uses libjasper as the jpeg2000 library. Jasper
> doesn't work very well unfortunately with some real world images.
> You might want to compile GDAL against one of the other JPEG2000 libraries
> that are supported : see http://gdal.org/formats_list.html
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140425/89bd5620/attachment.html>
