[gdal-dev] debug ogr2ogr on Windows
Martin Landa landa.martin at gmail.com
Fri Apr 25 10:31:08 PDT 2014
Hi Ivan,
2014-04-24 23:27 GMT+02:00 Ivan Lucena <lucena_ivan at hotmail.com>:
first of all, thanks a lot for very useful notes!
> Press F7 will build everything but you don't need to do that if you have
> done in command line.
I tried to build GDAL also from VC, but it ends with
1>      lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
1>nitf_gcprpc.obj : warning LNK4221: This object file does not define
any previously undefined public symbols, so it will not be used by any
link operation that consumes this library
1>      link /nologo /dll /INCLUDE:_OGRFeatureStylePuller
/INCLUDE:_OSRValidate  /INCLUDE:_OPTGetProjectionMethods
/INCLUDE:_OGR_G_GetPointCount  /INCLUDE:_OGRRegisterAll
/INCLUDE:_GDALSimpleImageWarp at 36  /INCLUDE:_GDALReprojectImage at 48
/INCLUDE:_GDALComputeMedianCutPCT at 32  /INCLUDE:_GDALDitherRGB2PCT at 28
/INCLUDE:_OCTNewCoordinateTransformation at 8  port\*.obj gcore\*.obj
alg\*.obj frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
  C:\oraclexe\app\oracle\product\11.2.0\server\oci\lib\msvc\ociw32.lib
 C:\oraclexe\app\oracle\product\11.2.0\server\oci\lib\msvc\oci.lib
                          odbc32.lib odbccp32.lib user32.lib
           ws2_32.lib gcore\Version.res  /out:gdal111.dll
/implib:gdal_i.lib   /debug
1>     Creating library gdal_i.lib and object gdal_i.exp
1>cpl_http.obj : error LNK2019: unresolved external symbol
__imp__curl_easy_setopt referenced in function "void __cdecl
CPLHTTPSetOptions(void *,char * *)"
(?CPLHTTPSetOptions@@YAXPAXPAPAD at Z)
1>cpl_vsil_curl.obj : error LNK2001: unresolved external symbol
1>cpl_vsil_curl_streaming.obj : error LNK2001: unresolved external
symbol __imp__curl_easy_setopt
Any idea what could be wrong?
> 5. Prepare a command line on Project/Properties/debug
> I can give more info tomorrow. I can't remember how the UI goes but is very
> simple.
Thanks in advance for very valuable help! Martin
